Return to Index
Read Responses
Never understood that argument, crimp is rigid too.
In Response To:
When you solder you make a rigid connection rather than flexible
Solder vs. crimp connectors
Watch the type of solder, but otherwise it's fine to use solder.
I'll do my best to give you my spin on flex
That is what I was always taught too...
solder is better if done correctly
I was always told to crimp if the amp draw was going to be high
Our Raymarine auto pilot motor's solder connections did that.
Crimp connectors with shrink tubing & sealant are really good.
If the wire is tinned I'd always crimp
Problem comes with the adjacent connection.
I did note that some would say that solder is better; however, let's go to ABYC
