Return to Index
Read Responses
I have a strobe at the top of the mast.
In Response To:
The problem with an SOS signal . . .
It would probably make some curious enough to wonder if help was needed.
LED Flares
Re: LED Flares
Larry, good luck with that
Re: Larry, good luck with that
Re: LED Flares
Wouldn't hurt to carry both
Re: LED Flares
Re: LED Flares I saw an article about these recently . . .
Jeremy things change, the SiriusSignal SSS C-1001 in CG approved for night use
Re: Jeremy things change, so that must flash SOS if I read 46 CFR 161.013 correctly
Yes it does, for about 8 hours based on full battery life.
I agree that flag or led is likely ineffective...also regular flares ineffective
Good plan to try, we have one also. We see folks in Mexico that leave their strobe on for any night
Re: We also have a strobe at the top of the mast.
Re: Concorde
Re: Concorde
