Return to Index
Read Responses
I can see now reason it can't, Max. As long as the thickness is up to the task, why not?
In Response To:
DQOTD - can industrial aluminum tubing be used for a whisker pole?
Re: DQOTD - can industrial aluminum tubing be used for a whisker pole?
clear coat
Sure, I've seen it done
The only question is weight...
Yes, Interior diameter is immediate issue
Interesting idea. You can get "pipe" and "tube."
It can corrode from the inside, or the rivets or screws or their "holes" may corrode.
Re: Did it to fix my pretzeled Whisker Pole.
Thanks everyone. I look forward to having an easy-to-handle whisker pole.
