Return to Index
Read Responses
Bedded bronze drain inlet (scupper)?
In Response To:
Here's one of the deck scuppers that drains the seat/bridge when heeled, Al.
Does it drain to the cockpit floor or "tee" into a cockpit drain to a thru-hull?
Installing cockpit drains.
Drain channels
Their effectiveness quickly diminishes on a heel, Al.
It's piped into this, a few inches below the deck.
That'll do it! Not too collision friendly, though ;^)))
Mine is nearly the same.
Those deck scuppers are a lot of work just keep topsides clean.
I must have been in a New England state of mind reading that
I've got scuppers through the toe rail.
Islander was setup the same way
Cockpit drains.
Here's where a seat/bridgedeck scupper would be handy.
This shot also reminds me how important the strength of the locker bullnose and clasps
bridgedeck scupper
Re: bridgedeck scupper
Unless, you are changing the position, and angles of the cockpit...
That's a Morgan design and the owner sails the boat on that heel quite a bit.
racers
My old Morgan 24 had the same issue.
