Return to Index
Read Responses
Re: Did you end up replacing with a newer Adler Barbour?
In Response To:
Re: Convert ice box to refrig/freezer... Engel has an ice box conversion.
Curious what how your new system compared to your old one
Sea Frost is the unit that I'd use. Made in New England, servicable nearby, etc.
I've been delighted with the Sea Frost unit I added to my icebox a couple years ago.
Our engine-driven, holding-plate, SeaFrost has run for three decades now.
Engel
Re: Convert ice box to refrig/freezer. I would call Technautics @ 949-770-9616 and
YES! First hand (no pun intended) experience
Well, you tried to do more than an icebox conversion...
all true
Re: Did you end up replacing with a newer Adler Barbour? Have not done either, yet.
My experience installing 2 systems.
Re: Wow - that was some project!
Re: Wow - that was some project! I bet it was.
What is your Insulation like ...
Re: What is your Insulation like ... needs work
Here's an Excellent article on Frig Box rebuild ...
Re: Here's an Excellent article on Frig Box rebuild ... thanks!
Re: What is your Insulation like ... 30 years old.
Re: Wow - that was some project! / You don't have to tear
Gawd, sounds like removeing tonsils from the other end...
Re: Gawd, sounds like removeing tonsils / Yes it was. On both counts! 😂
