Return to Index
Read Responses
Re: Here's an Excellent article on Frig Box rebuild ... thanks!
In Response To:
Thanks for the links - great information - looks like a great start - much appreciated!
Convert ice box to refrig/freezer
Sea Frost is the unit that I'd use. Made in New England, servicable nearby, etc.
I've been delighted with the Sea Frost unit I added to my icebox a couple years ago.
Our engine-driven, holding-plate, SeaFrost has run for three decades now.
Engel
Re: Convert ice box to refrig/freezer. I would call Technautics @ 949-770-9616 and
Re: Convert ice box to refrig/freezer... Engel has an ice box conversion.
YES! First hand (no pun intended) experience
Well, you tried to do more than an icebox conversion...
all true
Re: Did you end up replacing with a newer Adler Barbour?
Re: Did you end up replacing with a newer Adler Barbour? Have not done either, yet.
My experience installing 2 systems.
Re: Wow - that was some project!
Re: Wow - that was some project! I bet it was.
What is your Insulation like ...
Re: What is your Insulation like ... needs work
Re: What is your Insulation like ... 30 years old.
Re: Wow - that was some project! / You don't have to tear
Gawd, sounds like removeing tonsils from the other end...
Re: Gawd, sounds like removeing tonsils / Yes it was. On both counts! 😂
