Thanks Larry! I'll be more than happy to show her off. Also a strong possibility of passing your way this fall between the Newport and Annapolis shows. (the shows aren't a for sure thing but heading south in the fall is likely bankable. Whether to a ship in the spring or a 'fast' delivery through the Canal remains to be seen...
It's kind of intriguing that it's exactly 10 years since we moved aboard our Mainecat 41 end of April 2006 in Bremen and basically did the same thing. This time it's not our sole home and I'm viewing it more as a fun daysailer/weekender, but one that can stretch her legs when unleashed and one that I, at least could spend extended time on. The Admiral? well, I've pretty much reduced expectations in part, because I know how much 'stuff' I took off the last one we were living on even a number of years after we'd moved off.
