Return to Index
Read Responses
I put one of these under the dash of the Land Rover
In Response To:
Yes, I know. But I have a 12V search light.
Two 12v and two USB outlets. I'm sure they make several flush mount versions.
An ignition panel for the new cockpit.
I'm impressed with every new post Tom
Are you going to use an insert for the finger hole?
That's it - just the recess. It doesn't go all the way through the Lexan and is easy to slide.
Re: That's it - just the recess. It doesn't go all the way through the Lexan and is easy to slide.
Rockport Marine rents moorings, Chris.
We'll be neighbors this summer
Congratulations, I'll be looking for you, Chris(and your new boat!)
congratulations in advance
Re: congratulations in advance
The "stuff" can really add up
Continually well thought-out
Wow, really great work.
Then this occurred to me.
You can get a USB outlet
That old bone crusher looks like fun, Paul.
"I'll never forget the ride and the noise."
Re: I put one of these under the dash of the Land Rover
The Rivet Counters will frown on much of what I've done on this rebuild.
That's from when Land and Range Rovers made their name. Those are models like we saw in Africa --
I was impressed by some of those wannabe sport utilities at Winter Romp
Re: I was impressed by some of those wannabe sport utilities at Winter Romp
Re: Then this occurred to me.
True. I've experienced that. This isn't a home, just another place to move the tablet to.
Here's my now deceased crew.
No, here, really. She had a trim for the summer, she was a wire hair, long leg, JRT. 15 years.
You can tell she was a great dog.
Yes that looks like a great spot for it
And what, Tom, are the two rocks about on the leeward deck? :^)))
Like tons of flotsam over the years, they're en route to our house. Could have named Xmas, SCAVENGER
