Yes, found different keyboards. when we were in Venezuela, we bought an emergency keyboard replacement. not qwerty. But needed something. also, even though a board is qwerty,some special keys are different requiring an alt and shift for @ for example. need to check carefully Also it will have a 220 plug, but usually these take any power from 90 to 240 or something like that and either 50/60 hz and then use an inverter. so only need an adapter. I have adapters for my adapters - propane, water, electric - that;s the life of cruising
rickf
