The Campbell is simple, efficient and smooth and has less drag than the comparable Michigan Wheel. Tossed around mechanical props, feathering and folding, but in Maine with lobster pots I have seen just one to many on the re-build tables due to hitting pots. If I destroy a CS I am only out $500, a Max Prop in the thousands....
