Return to Index
Read Responses
Upp! My nautical dictionary failed my mouth. . . (pic)
In Response To:
Did you mean cleats?
There actually were no chocks. The lines were run over the toe rail to the cleats.
Anchor pull with engine in reverse test.
That sounds like something you could generate yourself by
Thought about purchasing one a while back
Windage
One way
You are assuming the same efficiency in reverse?
in the whole, yes
you can't assume that an anchor will hold at x force on any given day... It doesn't matter anyway... (link)
Exactly (nm)
Hmmm? Yeah,, that might be something to play with
We do something similar, but more violent . . . (pic)
Be very careful with that!
I guess you found out that...
Well, them tupperware things have a problem . . . (pic)
Here we are - with the Coelan before paint. . . (pic)
Opps - this one. (nm) (pic)
How fast does your boat go at 1500 RPM?
Burying the anchor
did the old tee shirt have anyone still in it? :) (nm)
On my motor.. (pic)
Going by those specs we should all be concerned. (pic)
How do you like your Campbell Prop?
I really do like it
Thanks Maine Sail! I had similar thoughts.
