Return to Index
Read Responses
Here we are - with the Coelan before paint. . . (pic)
In Response To:
Well, them tupperware things have a problem . . . (pic)
There is a backing for all of that area below that spans three deck beams and 8 planks.
Anchor pull with engine in reverse test.
That sounds like something you could generate yourself by
Thought about purchasing one a while back
Windage
One way
You are assuming the same efficiency in reverse?
in the whole, yes
you can't assume that an anchor will hold at x force on any given day... It doesn't matter anyway... (link)
Exactly (nm)
Hmmm? Yeah,, that might be something to play with
We do something similar, but more violent . . . (pic)
Be very careful with that!
I guess you found out that...
Opps - this one. (nm) (pic)
Did you mean cleats?
Upp! My nautical dictionary failed my mouth. . . (pic)
How fast does your boat go at 1500 RPM?
Burying the anchor
did the old tee shirt have anyone still in it? :) (nm)
On my motor.. (pic)
Going by those specs we should all be concerned. (pic)
How do you like your Campbell Prop?
I really do like it
Thanks Maine Sail! I had similar thoughts.
