Return to Index
Read Responses
I had PEX at my lake home - this was the Manifold.
In Response To:
best valves for manifold?
Eight Cold Water lines and Six hot. On - Off Valves right at the Manifold. Worked great!
PEX Manabloc Manifold
Water Manifold
If you are replacing everything...
PEX is great for pressure systems.
I would use the PEX with the slip on fittings
Kinking & Collapsing
hose
I'd back that up with this caveat
Ron -- How many LF of hose are you using?
Another vote for PEX
Thanks, Tas!
Thanks SG. Good point!
Yes, last time I bought H/C pressure hose, I bought in bulk.
I'd also suggest PEX...
Thank you!
Another valve option
I've read all these and while I use a lot of Pex tubing, I don't think I'd use in on my boat.
Are PEX fittings different from SeaTech?
Inch vs Metric
Your fittings shouldn't have leaked Dave.
