Any bowl that has a + 4 bolt mounting pattern--which is 99% of 'em--will fit it...so you could salvage one off any brand. The only issue is whether the larger 'highboy' bowl is too wide to fit next the pump handle.
I have the drawing for the Skipper...and will be glad to scan and email it to you.
