drilled holes and used a hack saw blade with a hook to pull out any remaining core mush (there wasn't much). No water came out the drilled holes. I plan to use a heat gun and air compressor to dry out the area as best I can, then I will try and make a circular wooden insert and add as much epoxy as possible. Thoughts??
Thanks!
