Return to Index
Read Responses
Anyone ever connected a WM AIS-1000 to a Lowrance HDS-7?
The LEDs on the AIS say it's happy, but no info seems to be getting into the chartplotter.
Have you tried plugging the serial connection into your laptop and used ProAIS?
NMEA in- / NMEA out-
In the HDS Manual
Speaking of "Com ports", I have to connect
In WIndows?
Thanks, My knowledge base is pretty thin
Why do you need to change it?
The only reason I would change
Once you set it, the ProAIS program should remember the com port setting
So you are saying that with the AIS I'll
No I said just the opposite. Once you set it up it should be good
What happens is that when I bring up the
What's on com 3? If nothing, rename com 7 to com 3
When I do the Computer, device manager properties etc.
Do you have a Blackberry?
Larry, it's much more clear and
Glad to help
Larry, I reconfigured the AIS to the correct
Brendon is going to make the trip back up the Baja
Have a good bash
Thanks, Ed. We'll give it our best.
Have you set your connection to 38400?
Thanks all, I will be trying again tomorrow.
For the record, I had it miswired.
