Larry, it's much more clear and
In Response To: Do you have a Blackberry? ()
so I would like to say thanks. I do have a blackberry but I no longer use it so I will try to remove them and rename the AIS to com 3. Now that I'm back on the boat I can start playing with it to see what happens. I'm having the injector pump pulled tomorrow and then a bottom job prior to heading back to Calif. so it's not like I won't have time to mess with it.
