Return to Index
Read Responses
Speaking of "Com ports", I have to connect
In Response To:
In the HDS Manual
to "Com 7" when I connect my WM AIS. How would I go about changing which port I connect it to?
Anyone ever connected a WM AIS-1000 to a Lowrance HDS-7?
Have you tried plugging the serial connection into your laptop and used ProAIS?
NMEA in- / NMEA out-
In the HDS Manual
In WIndows?
Thanks, My knowledge base is pretty thin
Why do you need to change it?
The only reason I would change
Once you set it, the ProAIS program should remember the com port setting
So you are saying that with the AIS I'll
No I said just the opposite. Once you set it up it should be good
What happens is that when I bring up the
What's on com 3? If nothing, rename com 7 to com 3
When I do the Computer, device manager properties etc.
Do you have a Blackberry?
Larry, it's much more clear and
Glad to help
Larry, I reconfigured the AIS to the correct
Brendon is going to make the trip back up the Baja
Have a good bash
Thanks, Ed. We'll give it our best.
Have you set your connection to 38400?
Thanks all, I will be trying again tomorrow.
For the record, I had it miswired.
