Shell Rotella T 15-40 is the big seller here, but I use Chevron or Texaco CH or higher rated oil...
No real difference from one brand to the other. I don't use Shell Rotell T because it is only available in gallons locally. Both the Chevron and Texaco diesel rated oils are available in both quarts and gallons here. My engine takes just over 5 quarts.
