Return to Index
Read Responses
Thanks Paul and Todd!
In Response To:
Add my vote for Shell Rotella
It seemed strange require an outdated grade. Good luck with Earl, David
DQOTD: diesel engine lubricating oil
maybe not harmful but probably not helpful
2nd the Rotella..using it in my Cummins for years
The viscocity does not determie ratiing alone
The easy way to remember is "s" = spark, "c" = compression - method of ignition
The viscosity, like Doug says, is not what
Shell Rotella T 15-40 is the big seller here, but I use Chevron or Texaco CH or higher rated oil...
I have a new Yanmar 3YM30
Hope Earl is good and tired by the time he reaches Nova scotia.
CH and CJ exceed the CD spec and will be better.
Brand doesn't matter - all the majors make diesel rated oil
As explained to me by the local Peterbuilt dealer
I like Chevron Delo
