Return to Index
Read Responses
Add my vote for Shell Rotella
In Response To:
I have a new Yanmar 3YM30
Perhaps this link will help, David.
http://www.upmpg.com/motor_oil_rate_gas.htm
DQOTD: diesel engine lubricating oil
maybe not harmful but probably not helpful
2nd the Rotella..using it in my Cummins for years
The viscocity does not determie ratiing alone
The easy way to remember is "s" = spark, "c" = compression - method of ignition
The viscosity, like Doug says, is not what
Shell Rotella T 15-40 is the big seller here, but I use Chevron or Texaco CH or higher rated oil...
Thanks Paul and Todd!
Hope Earl is good and tired by the time he reaches Nova scotia.
CH and CJ exceed the CD spec and will be better.
Brand doesn't matter - all the majors make diesel rated oil
As explained to me by the local Peterbuilt dealer
I like Chevron Delo
