I like the idea of the pin.
Since the pole is fixed to the mast, the pin could just drop in from the top - gravity would hold it in place. A piece of small stuff would hold it when the pole was retracted. I had some two-piece dingy oars with those spring loaded push pins - never worked right. They seemed to shift inside the small tube, and didn't align properly with the hole in the small tube - hence wouldn't engage the larger tube.
