I guess mine is not the same after all. I
In Response To: kemp pole ()
have the buttons to extend the pole but the end fittings are SS and cast aluminium. I've never seen a pole with plastic end fittings. If you feel like trying what I did, cut the pole just after the end cap and cut the remaining aluminium off with a Drimmel and cut off wheel. A couple of inches off the pole won't matter when you decide where to place the new pin.
