the end fitting is cast, there is a plastic ring where the smaller pole
goes into the larger pole. this ring on the larger one keeps the smaller
end from turning. guess my description wasn't good.
I've attached a pic. the plastic ring is what keeps the poles from separating
I think. note the little black dot just up from the ring. This keeps the plastic
end in I think
