Return to Index
Read Responses
how would you mount it in a narrow deep bilge?
In Response To:
I always go with a dedicated through-hull in such a case
Looking for ideas.
No doubt only the switch and intake need be mounted low.
Looking for ideas regarding electric bilge pump installation.
With a properly installed vented loop -- I'd tie the two together
We recently did this in a Dana which has quite a deep sump
How do you test this... Rule has such a sensor too.
If it's a deep bilge and you have the pump on a stick
Deep Bilge, Pump Install
Ditto
Good point! So is Ron's about redundant systems.
Tom -- the connector is after the vented loop(s) on the "downside"
How about a remote pump installation?
You would want to keep in mind...
bilge pump ideas
Good ideas...
