Return to Index
Read Responses
I forgot, the reefing turning block is the ratcheting style
In Response To:
We just installed some Harken 57mm Carbos
looking for idea to reduce "friction" at a turning block...
you did not say how the lines are run
Good question... for the most part ball bearing stanchion blocks...
A photo of the block in question would help
I must be missing something
Kind of an odd ball thing actually...
Try a wire block?
OK so they don't make large diameter sheaves for small lines?
Gene, you don't need a small line block.
Dunno why you don't have a larger diameter ball bearing block there...at's what I'd do.
Something like this?
What are you attaching it to, Gene?
good image...
The camlock may be a problem too
Bearings on the block? I suggest this
Hmmm... am I understanding this wrong?
I thought I knew what you meant, except...
