Depending on your direction of pull, you may have significant friction as the line goes through the fairlead at the end of the camlock. If it is normally swiveled so the pull is in line with the block, then maybe not a problem at all. Still, pulling up over the cams would cause some drag. You could always test that by bypassing the camlock. You have probably looked at all of that already.
