forgot to mention the stove thing, fresh water update
In Response To: cruising questions ()
(in a really tiny font and a quiet voice) I removed the pressurized alcohol stove over the winter cause I almost set fire to the overhead while testing it. Replaced it with a totally electric cooktop figuring that we would be going slip to slip and always have shorepower anyhow. Copied the setup from a dockmate with a 28 Tartan.
I was looking this morning at the Seaward butane single burner as a supplement?
Went down yesterday, found the bilge full and the water tank empty again. According to SURflow, they no longer make parts for my model 200 pump, so that needs to be replaced. If anyone needs them, Whale Gusher Galley MkII rebuild kits are available from Iboats.com for $20.
