Return to Index
Read Responses
That looks like a great system for a single reef but what
In Response To:
What the shuttle block does...
do you do about the second or even a third reef? Wouldn't the boom ends would require 6 exit points.
Single line reefing.
WHat size is your main?
P=34, E=11.5
Photo of sorts of my single line on a prior boat...
Actually, I can't recollect if the fore end of boom had sheaves or not...so best I can say is IIRC...
Well
I tried single line reefing and it
Reefing for us
Maybe I'm wrong but my
Another senior moment. Repaired.
I have it
Selden ditto, works fine...
Conclusions - so far.
Double Line
I am happy with double line
sded, I just installed exactly
Mine look like this
If you replace those eyelets with ball-bearing blocks it would work nicely
I like simple.
The same as mine
On my system I was limited to two reefs by sheaves in boom.
Yes 6 exit points for 3 reefs, but is that different than any system?
