Return to Index
Read Responses
He'll pick up damn near anyone.
In Response To:
Onset has a fella to drive you to the store and generally schlep your junk.
How many NMPG does your boat get?
Around 12
Were you doing a lot of battery charging or slow speed?
No, to my surprise...
Red Brook is beautiful
And the little restaurant is nice.
I just had a mechanic down to the boat discussing
I'd give him the 8 hrs plus 15%
That's a good start for negotiations, but you're paying him for his work not his estimating skills
It's always a tricky subject.
What I meant was
"Estimate" is a difficult word to define. I try to do it right up front.
I usually give a Will Not Exceed price
I would pay for the time to do the required repair...
I have used this fellow in the past and have
Sounds like he knew he screwed up and was decent enough not to try to pass the costs to you...
I do almost all of my own work but
I think you did the right thing... this guy made good at his rate.
No criticism about your decision from me. I wouldn't take an infector pump off either...
They're all different I'm sure, my injection pump is pretty easy to remove and install.
The pumps where the timing is adjusted by shims can be a real bear to get right.
Around .33 gallon per hour or
Really apples and oranges?
My a5 year average fuel consumption is 0.45 gph
15 year..damn fingers....If you want to learn a bit about fuel consumption read the link inside
I looked at the purty pickchoors....
Right around 7 NMPG
4+ 130 hp 6-354 Perkins pushing 42,000 lb
I seem to burn about 1.05 gal/hr...
Volvo folding prop -- 16x19 three blade
meant 19x16
Well, I don't agree with the "always run it at 80% +" crowd...
Given your fuel consumption you are likely putting out 17-18 hp...
Todd, what calulator are you using? Is it online?
I find the Wyman relationship between the most accurate for estimating power required under moderate conditions...
With my 80 gallon diesel tank, I'll probably never really know.
80 gallons for your boat?
Can someone tell me my range?
In 1961, the Graymarine gas engine was typical in boats like this.
