They're all different I'm sure, my injection pump is pretty easy to remove and install.
Removing the timing gear is a little tricky and requires a special tool (which I don't have), but the rest for an inline Bosch IP is pretty straight forward. Best of all, gears are clearly marked for reinstallation and the factory timing mark was still right on. A Nissan mechanic advised I set it there, he was right.
This mechanic above sounds like a good business man and kept a good customer.
