Link 2000
Boys-
I have a Link 2000 that is staying in the "Absorption" mode and will not go into "Float" mode. I have a voltage of 13.15v (my float voltage is 13.2v) and an amperage of .2 amp. My concern is that I may boil out my battery water if left on charge without going into float mode. Does anyone know if .2amp will cause a problem, or what could be causing the Link to be in Absorb rather than kick down to Float mode.
BTW, my batteries are 4 Trojan T-105 that are set up in 2 banks with a 1-2-Both switch. I can't get the link to go into float with either bank connected! This leads me to believe it's a fault in the Link. I just don't want to ruin my batts. I am plugged in to shore power full time.
Thanks!
Rodd
