Yes, I guess I should get out the old hydrometer and ck the cells. I am pretty sure the batts are good. question is will this constant amperage charging affect the batteries longer term? and why isn't the Link going into the float mode. one thing I must try this weekend is to reboot the Link by disconnecting it from the batteries and letting it repower on. Curious if it will still malfuntion or if it will "cure" itself!
Rodd
