Return to Index
Read Responses
Make sure it's set for lead acid when you reboot, Rodd.
In Response To:
thanks all ! some more info
Link 2000
You can put as much as 10 times the amps with no problem
thanks Dan!
Mine is always putting in 2.5 volts in float.
What is the indication that you are in Absoption mode?
Noticed a similar situation
The .2 is way low
On float, it should "tweak" the battery briefly
Float voltage
Link 2000 update
Hmph!
