You can put as much as 10 times the amps with no problem
In Response To: Link 2000 ()
Batteries won't boil at 13.2 volts. Your T-105s should take 2 full amps and not have a problem.
Go to the Trojan website. There's a lot of info. there.
When was the last time you did a hydrometer test of each cell in your battery bank? If the battery's are charged, let them sit for a while without the charge on and test each cell with the hydrometer (less than 10 dollars anywhere). You may get your answer.
