Hi Drake,
...after he shows up in Bermuda on a pretty impressive-looking 52-footer with no engine, no steering, blown-out sails, and claiming "he has no money for anything"??? Bermuda is a wonderfully hospitable place, but I doubt you'd get very far arriving in such a boat, then claiming to be destitute... (grin)
Good on you for assisting them, too bad this goes down as another example of no good deed going unpunished... About a month ago, I departed Hampton at approximately the same time as the Caribbean 1500 fleet, and the possibility of getting drawn into another boat's drama was most definitely on my mind, and was a major factor in sailing due East out of the Chesapeake initially, in an effort to separate ourselves from the herd as they headed down the beach to cross the Stream closer to Hatteras...
No emergency tiller of some sort on a boat with hydraulic steering? Wow...
best regards,
Jon
