If the line pulls from the oar 1" then the block has to move out 1". For the block to move out 1" there needs to be an 1" of line on each side or a total of 2". Since one end is fixed the only side that is moveable is the side that is connected to the wheel and thus it needs to pull the wheel 2".
Hope this helps.
Go Slow
Sail Far
Stay Long
