Return to Index
Read Responses
Thanks Todd, what size alternator do you have?
In Response To:
Actually the Volvo D2-40 uses a 1-3/4" exhaust
OMG Yanmar wants to put a big hole in my boat
Lack of backpressure is good :^))
Not cost but big hole in my hull
115 amp
That is the stock alternator on the D2-40
That's the diameter of the mixing elbow...Is that the diameter of the thru-hull?
Brochure
What's a Coast 34???
I've heard from other sister boats
A good friend had a Coast34
David makes a good point, but...
Your friend with the 3GM30 made a poor choice of gear ratio/prop pitch if he has that problem...
9 knots of current? Gaack!
Well, my favorite is Dodds Narrows out of Nanimo
Ok, well, I'm used to doing tides, so I should be able to figure it out,
current makes no difference, it's wind and waves that do.
Yup, pretty much true.
Both of you guys are right, hull speed is what it is, however,
Is that the one off West End coming in from the Banks Ron?
Right, Tom - Indian Pass, boats miss the channel and go up on the reef on a regular basis :0
That exhaust size seems excessive.
Not really Tom (s) When I installed my
But isn't 2 to 3" quite a jump up in hose and fitting space Ron?
It does complicate the job
Yes, as I mentioned above, on our boat, even though
