Return to Index
Read Responses
Same here, on two boats, three masts. Love 'em. Drop like rocks when halyard
In Response To:
I have metal slides in a metal track. I think these are outdated though.
released.
Third boat has nylon and internal track- don't work nearly as well.
What kind of slides does your mainsail use?
UV eventually gets plastic slugs. Metal ones slide easier....
For a fully battened sail
bainbridge allslip slides
Had bronze track and bronze slides on one boat, slid beautifully.
Yeah. Truth is, I'm too lazy to tape. Varnish gums them up for a few hoists, then they're fine.
I have the same bronze on bronze, Tom
I s'pose to a certain extent it's about how tightly they fit.
Gene, we have ball-bearing cars
Correction, if getting new sails
I have had a Strong Track for...
Thanks all, and good point Brian...
Gene - Were the slides that broke at the full length battens?
Yes, at the battens and down low
Did they break at the conjunction of the bale and the base?
Use straps that allow the batten to rotate without torquing the sail slides.
I replaced all of my slides
