The bottom line is that current
is being passed through the fuse. That means that the Sea Talk circuit is more negative then the solenoid negative is negative. Your job is to find out why. It could be that the solenoid has a bad connection forcing it to look elsewhere for a ground path. I would check every connection in the solenoid circuit as a starting point especially on the negative side.
