Return to Index
Read Responses
It soundlike a transient -- not continuous isse, Steve
In Response To:
The bottom line is that current
Engine kill switch blows Seatalk bus fuse?
Sounds like you engine alternator is causing a spike through your system. The Seatalk is just "sensitive" to the spike.
Maybe...
I was thinking along those lines, but...
I understand what you are saying but
Makes sense to me. Spring launch and electrical corrosion go hand in hand.
I gotta see a picture of it.. here's a try
Extrapolating a bit more on this idea
Not that simple
The TACH is connected directly to the Alternator...
Well yes but no. Sure sounds like I deserve a GOBI award though.
Then take the ground to the Seatalk
It's already direct to the battery
With NOTHING else connected to it?
I'm not going to mess with the main panel
I was suggesting going to the Seatalk...Not the panel.
Would try that if the hour-meter rewire doesn't do the trick
I'm with you Charlie. Here's what the mechanic said:
Ahh, that explanation seems to make sense.
That's what I was thinking a surge that should be surpressed....
How about a fuel shutoff cable? Works without any possible failure.
the hour-meter rewire did the trick
So the "What Changed?" troubleshooting question pointed to the solution... congrats!
BTW, where is that old GOBI award image? Dave Gibson???
Ah yes, the adjustable wrench with the 90 deg twist. Remember it well.
Kill switch saga continues. Any electrical wizards reading?
If your ohm meter is accurate...
The high co$t of green paint
I haven't read the whole thread but do you have a clamp on ammeter?
Could this be a symptom of a bad ground connection to the battery?
Found it!
Good detective work...
Thanks. I found a good guide for testing alternators on Fluke's site
