Return to Index
Read Responses
That's why I always put rat/mouse poison in any storage unit I'm using.
In Response To:
Don't you just love the little critters
Stowing avon RIB
I've always left mine inflated
I have a compact RIB - I deflate it and stow it in the bag for the winter
I do what Todd does... 10 years and no problems
Me too!
So all you folks have actual Rigid Inflatable Boats?
Stand out from the crowd Gene!
But Greg, the only way to store one of these is against the lifelines, no?
We store ours....
I have a compact RIB..
Second Todds wise advice.... IMHO you should go on a ride in a Avon Lite and a Portboat and then chose.
Absolutely correct!
...actually, our's is a high pressure air floor
The main thing is ...the Admiral thinks it's
...actually, I'm apparently having a bit of
I had an Avon set up that way and it was great.
Our high pressure floor exploded in the heat.
Wow, that's good to know - we have a white cover
I also deflate & store in bag provided
I always leave it inflated. Unless you
What "loads" are you talking about? There's no presaure.... inflation creates a "load" on the seam.
If you take two pieces of rubber and glue
Mine hangs upside down overhead in the garage.
Keep the mice away..
Got the washing machine too!
Damn I hate when that happens. Expensive repairs.
