A sailboat with 3 or more out for just a week or two, runs on food.
In Response To: Yeah 1.3 CU Ft. ()
Either that or it's a docking restaurant cruise. We need quite a bit of space and will have to shop along the way to replenish fresh food, at least once a week.
Initially in comparing energy used, I thought Todd was talking about his sailboat. A powerboat doesn't have much to compare. On an overnight, it's likely running an engine beyond what any refer requires for charging. On a sailboat, the goal is usually to get there under sail.
But then once you get somewhere, sail or power, the clock starts ticking. Even Dashews Windhorse which has acres of solar panels, when I circled it in Pulpit Harbor, had a generator running.
