Return to Index
Read Responses
Wow, glad it wasn't worse. I'd have a surveyor check it out anyway.
In Response To:
Should stayed in the water!
Ouch,... your boat is strong Al.
Re: Posting
Yeow! Unexpected! MUST have it surveyed at their expense ultimately.
Al, is the hull cored or solid?
Check the fillets at the stringers. And bulkheads too.
Hull is solid, VERY solid.
That is all the stands you need...
Engine alignment I can do..
I was more concerned about damage to the mounts.
No mounts, hard to the hull.
You got off easy.
I'm not sure it really was a "dead" drop -- like the strap snapped completely.
You are lucky...
