Return to Index
Read Responses
Yeow! Unexpected! MUST have it surveyed at their expense ultimately.
In Response To:
Should stayed in the water!
Wow, glad it wasn't worse. I'd have a surveyor check it out anyway.
Ouch,... your boat is strong Al.
Re: Posting
Al, is the hull cored or solid?
Check the fillets at the stringers. And bulkheads too.
Hull is solid, VERY solid.
That is all the stands you need...
Engine alignment I can do..
I was more concerned about damage to the mounts.
No mounts, hard to the hull.
You got off easy.
I'm not sure it really was a "dead" drop -- like the strap snapped completely.
You are lucky...
