I run my radar cable all the way to the display
In Response To: Radar cable connection? ()
I disconnect it at the display and pull it out when we drop the mast. It is a bit of a pain to pull the cable back in, but I leave a messenger line in place when I pull the cable out. I have a deck stepped mast too. I drilled a hole through my mast step so the cable can pass through inside the mast. No problem so far.
