I think a hole 6 inches off the deck
is fine as long as it's not some huge hole. It depends on the size of the mast but I wouldn't be against an eyeball guess as to what's over the limit. If you can get some good connectors and seal up the cover plat I don't see why it wouldn't work just fine. Tape everything with some rubber safety tape after you get it plugged together and you should be fine.
