Return to Index
Read Responses
Seems to me that all the bits of the seal have to be put on with the shaft IN the boat
In Response To:
The would have had to install the "guide" on the shaft, then put the seal over it. But still?
No reason to pull it that I can see.
WHAT? $1,375.25 to fix a new dripless that Hinkley installed wrong!
Hmmm ?
Me neither. Hadn't expected them to pull the shaft.
You want my opinion of boat yards in Florida > No, you don't. Sorry about that Dan ...
Dan, That really sucks! I had a similar
Port Annapolis has a reputation as a good yard. Talk with them about it.
I did with no consideration on the hours.
Post Everywhere
That's all that had to be done, slide it back, install and slide it forward.
I don't know the laws in MD but
Dan, if you asked them and they didn't send you a quote then
You will learn the hard way ...
John, you're almost right. If you're a
Yeah, you got that right Steve ...
Not to Hassle, but....
I have been overcharged (IMO) by several yards in New England...
