They even have on the invoice that they removed 3 large hoses to get to the fitting. I'm 6'4" and weigh 210 lbs. Although it's a tight fit neither I nor the yard guys at Hinckley needed to remove anything to get to the Lasdrop.
I'll stick with the idea that it's been a slow winter and the memo came down to get the hours up so Port Annapolis doesn't have to work on a negative as far as the on staff personnel are concerned.
As said. I'm just going to pay the bill and remember.
Thanks for the support guys. You've all been there I'm sure.
