 () Both the items key to the problem are high load in most cases. Your propane solenoid is held open by a constant voltage - should an inordinate load reduce that voltage below a certain level it would allow the solenoid to close, setting off the alarm feature on some set-ups. ...maybe, possibly, could be, I think!
